Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor
G.Barozzi
Shell element thickness incorrectly displayed
208 Views, 1 Replies
08-24-2013 12:31 AM
Autodesk Simulation Mechanical 2014 Service Pack 1
Analysis type: Static Stress with nonlinear material model.
In the Edit Element Definition dialog for Shell elements, after setting the shell thickness to the desired value the change is accepted by clicking the OK button.
If I open again the same dialog, the shell thickness is set to 1mm, whichever value I have inserted before.
However, in the report the element thickness is correctly displayed.
Thank You
G. Barozzi
Please use plain text.
Active Member
randymusk
Re: Shell element thickness incorrectly displayed
08-28-2013 04:01 AM in reply to: G.Barozzi
Yes, I have seen the same thing.
Ranman
