Hello!
I have two questions and hope that you will help me.
While doing some of the tutorials I came across the "Heat Flow Calculation"-setting in Edit - Element Data. today, but although I read the paragraph about it in the wiki I still do not completly understand what it means. Could you please explain me the difference between Projected at Centroid, Nonlinear Based on BC and Linear Based on BC ?
The other question is: is it possible to use a function to describe a border condition? In my case I need to do a transient heat flux calculation and simulate sun shine. Since the incoming heat flux varies with the sun's elevation angle ("cosine law"), I need to take that into account and attach the border condition to the time variable. How can this be done?
To go even further, is it possible to use a given set of measured data points so that a interpolated function is used to define a border condition?
I hope that you can help me.
Kind regards,
Walter
Hello!
Meanwhile I found out that using a changing input should be done using a "load curve".
This page describes different ways to create a load curve:
I entered some points to create a load curve. So far it works. But I can not find the textfield to enter a mathematical formula, nor the Equation Editor. Since I am trying to do a transient heat transfer - is the formula editor only to some of the analysis types? Can you tell me where it is? (Multiphysics 2012)
And to my other question concerning the heat flux calculation:
Could you please explain me the difference between Projected at Centroid, Nonlinear Based on BC and Linear Based on BC?
Kind regards,
Walter
Ok, I found the equation editor 🙂 Finally...
Is it NOT found using "Analysis Type - Analysis Parameters - Load curve", although you can create load curves there.
The equation editor is available after in the dialog that appears after adding a load to a surface. Click "View/Edit Load curve" there, and another window appears. The equation editor is available there.
Is there a reason why the equation editor is not available in the Analysis Parameters - Load curve or is the user interface just a little bit inconsistent? 🙂
Kind regards,
Walter
