I’m working on a beam element model where I have just 1 part defined with several beam cross sections defined as different layers. Is there a way in the results environment to select a beam based on its layer number (cross section)? I’m looking for something like “layer control” in the results environment but I don’t see it.
Hi Steve,
The layer number does not exist in the Results environment, but there is something similar that may work in your case.
