I am pretty new to autodesk simulation and FEA analyses. Now I am in a state where I can create models and do the analyses that I need. I would like to make use of the "scheduled analysis" function in the analysis tab of Autodesk Simulation Mechanical SP1. I am doing linear static stress analyses and MES with 3D models. Unfortunately, I have to create a volumetric mesh of all my design scenarios before I can run them with "scheduled analysis". Without the volumetric mesh it does not work and the analyses are aborted during the scheduled run. I have a lot of different design scenarios and it is quite inconvenient to mesh them manually. Is there a possibility to schedule the volumetric meshing prior to the scheduled analysis? Or is there an option which enables the volumetric meshing during the scheduled analysis. Any help is highly appreciated.
Cheers in advance
Thomas
Solved by AstroJohnPE. Go to Solution.
Hi Thomas,
I am not aware of any option that will automatically perform the solid meshing as part of a scheduled analysis. But here are a couple of ideas that come to mind.
Creating batch files is not for everyone, so I have not spent the time here to include those details. If someone would like to get into it, I can elaborate later.
Hi John,
thanks very much for the quick reply. Unfortunately I only have 3 month of experience with mechanical simulation, which might also say something about my age 🙂
I already tried to use algormeshrun.exe to force the solid meshing of the design scenarios of my model. I read the options (see image) after opening the algormeshrun.exe in cmd.exe. However, I do not know the syntax to get it running and I am not sure if I can force the meshing with algormeshrun.exe. I tried some of the commands (-f, -zf 0) shown in the image and the task seemed to start but than sort of hung up. I don't know if I understood you correctly, but if you could provide a batch file where the syntax is shown, that would be wonderful.
Cheers,
Thomas
You know that you are getting older when you have no recollection of something that you did less than a year ago! Here's a file I found on my computer that shows how to use the AlgorMeshRun. You would save this text to a .BAT file.
:: JWH 2013 April 8
:: The "--" is required!
:: DO NOT use "\" for the runtime options. Use -f, -d, -z instead of \-f, \-d, \-z
:: A space is required between the option and the argument. Use -d 1 instead of -d1.
"C:\Program Files\Autodesk\Simulation 2013\algormeshrun.exe" -- \-f "C:\Support\Test\BRACK.fem" \-d 1 \-pf \-sf \-z 1
"C:\Program Files\Autodesk\Simulation 2013\algormeshrun.exe" -- \-f "C:\Support\Test\BRACK.fem" \-d 2 \-pf \-sf \-z 1
"C:\Program Files\Autodesk\Simulation 2013\algormeshrun.exe" -- \-f "C:\Support\Test\BRACK.fem" \-d 3 \-pf \-sf \-z 1
"C:\Program Files\Autodesk\Simulation 2013\algormeshrun.exe" -- \-f "C:\Support\Test\BRACK.fem" \-d 7 \-pf \-sf \-z 1
"C:\Program Files\Autodesk\Simulation 2013\algor.exe" \-s all "C:\Support\Test\BRACK.fem"
where
Then algor.exe runs the analysis on all of the design scenarios, which presumably were 1, 2, 3, and 7 in this model.
Dear John,
I just tried the meshing with one of my models and it worked. The"--" before the -f command did the trick. Thank you very very much. This will save a lot of time and nervs. I am glad to benefit from your experience.
Thanks again
Thomas
Hi everyone,
I have usually been able to just run a modal analysis live with no issues and get results within 40 minutes, from a day to another it began to show "Scheduled" at the top left of the screen in the data tree, and it does not go anywhere.
Does anyone have any idea of what my problem is? I attached a screenshot of where it is showing SCHEDULED in my screen below.
