Hello
I am a new autodesk simulation mechanical user.
I am using Autodesk Simulation Mechanical 2015 R1
I am having some problem with the results visualization. I want to show "shaded with mesh" visual style but I don´t get it. I can´t either see the reactions. I am following steps tutorial. Is there any problem with this release?
Thanks in advance
Solved by Andrew.Sartorelli. Go to Solution.
Hello
I have been talking with my Autodesk distributor, and we have fixed the problem. The post-processor doesn´t work, there was a problem with and old Autodesk Revit 2012 windows registry.
I post the solution if it can help someone.
Hi iegia,
Glad to hear everything is working for you now! Based on your description, I believe the following was the solution your distributor/reseller likely provided you 🙂
Using the registry editor (RegEdit.exe) modify the conflicting registry key:
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
