Hello!
I am working on the simulation of fracture, where crack is initiated inside the tube. Stress values on model (Results section) is not much visible, because they are hidden inside the tube.
Q: Can be the results (stress distribution) shown in the sectional view? (just like the "cut" or "sectional view" in Inventor)
Thanks a lot!
In the tree view, there is Presentation->stress->Slice Planes. After adding a new one, you should be ok to view the stress on the cross-section.
I had a similar task recently.
When the section is cutting between the nodes.
What result does the section show. The interpolated results at the exact position of the section, or the results of the next node you are looking at through the section?
Regards
Boris
