Simulation Mechanical and Multiphysics
1 Kudo
Results Font Size
127 Views, 2 Replies
01-07-2014 07:13 AM
Is there any way to increase the font size of the results?  (i.e. von mises, displacement magnitude)  I noticed in the the application options you can increase the size of the scale and the ucs icon, but I couldn't find anthing relating to the results scale.  I've attached a pic with the exact area in question circled in red.
Adrian
Distinguished Contributor
34 Kudos
Re: Results Font Size
01-07-2014 07:16 PM in reply to: powder1742
Hi Adrian,
Everything about the legend can be edited via Results Contours > Settings > Legend Properties. In this case, go to the Legend Properties tab inside the dialog and click on Font... You should be able to change the font size for the legend here.
Regards
Ilyas
1 Kudo
01-08-2014 05:40 AM in reply to: powder1742
Thanks Llyas.  That is exactly what I was looking for!  I appreciate it.
Adrian
