Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Results doesn't show color gradient
1 REPLY 1
GersonMachado8699
651 Views, 1 Reply
I am having a problem viewing my results. I used one computer to run the model analysis, without any problem. I could see the results fine. However when I opened the model results on my laptop I wasn't able to visualise the results color. The results show me all elements in white (not blue!), with no color gradient. Does anyone know how to solve this problem?
Yossef Sami El Didi
1 REPLY 1
Hi Yossef,
I've seen this issue pop-up quite a few times on support. You can typically resolve it by disabling OpenGL hardware acceleration in Simulation Mechanical.  The following technical article describes the steps of how to do so, http://knowledge.autodesk.com/support/simulation-mechanical/troubleshooting/caas/sfdcarticles/sfdcar...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Andrew Sartorelli - Autodesk GmbH
