Hello Everyone!
I am creating reports for my analysis and I cannot find a way to make the automatizally inserted Results Presentation images bigger.
Their size is of ridiculous 400x300.
How can I make it as big as the title image?
Thanks a lot!
See my thread http://forums.autodesk.com/t5/Autodesk-Simulation/Results-Images-Within-HTM-Report/m-p/3198758
Nearly a month ago lol. I guess this part of the application is low priority. On a side note, I would like a way to export an image without having to enclose a window around it, just the entire image. I end up with images of slightly different sizes because of this. Not a big deal but it is to me. Thanks
Hey Andrew,
I also had the feeling. I was expecting to be able to customize way more the report, but it is impossible. Anyway, I think that in order to do what you want you can simply go to the main menu -> export -> image.
This way you can export exactly what you see on the screen.
Thanks anyway for the reply. I hope someone from Autodesk says somehting about it.
Thanks I am using 2011.. I was talking about file-export-image but in my version it forces me to select the image manually with a window. Do I just double-click or something? Thanks for the reply though
I recommend than you using a third party software such as SnagIt.
It is really great for screen captures.
I have tried to use the report functions and have given up. I now make any jpg that I need and use a Word document that has all the simple sections and boiler plate needed. I even have several of those: for sending to the customer or documenting for internal use. I have been reviewing ANSYS and its reporting is not much better than Simulation's.
I guess we can only hope that in the future they will realise that reports are a very important aspect of the workflow and shouldn't be left aside.
