I am running a transient heat transfer problem with body to body radiation. I am getting a view factor error.
Calculating view factors for enclosure 4.
Error: view factors sum = 1.1435 must be >= 0 and < 1
(tolerance used=0.11) for an open enclosure.
This is not the case for surface number 1376!
Your mesh is probably too coarse.
This enclosure has 6 defined surfaces, how do I tell which one is the problem? I want to add mesh refinement points only in the problem area. I do not have any surfaces on any part numbered 1376.
