Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Relating view factor error surfaces to part surfaces
0 REPLIES 0
Message 1 of 1
cummingsga
270 Views, 0 Replies
I am running a transient heat transfer problem with body to body radiation.  I am getting a view factor error.
 Calculating view factors for enclosure 4.
 Error: view factors sum = 1.1435 must be >= 0 and < 1
        (tolerance used=0.11) for an open enclosure.
        This is not the case for surface number 1376!
 Your mesh is probably too coarse.
This enclosure has 6 defined surfaces, how do I tell which one is the problem?  I want to add mesh refinement points only in the problem area.  I do not have any surfaces on any part numbered 1376.
0 REPLIES 0
