I am a student taking a class in finite element analysis and we are learning how to use Fempro and Superdraw iii. I am wondering if anybody knows where I am able to get a copy of these programs that I can use on my personal computer.
Thank You.
Solved by Sualp.Ozel. Go to Solution.
Students can download the current "student" version of the software from the Autodesk website. You should be able to find it by searching for "Simulation Mechanical".
Once you use the current software, you probably will not want to use the old software that you have in your class. Superdraw 3 has not been part of the software for 4 years! A lot of things have changed since then.
Thank you for the response. I know that simulation is the most up to date software. But based on the class I am taking, they are teaching us how to use fempro and superdraw iii. These are the software that is on the school computers and I was just wondering if there is a way to get a copy of fempro and superdraw iii that I am able to use on my own personal computer.
If you are a student, you can download Simulation Mechanical to your personal computer per John's earlier discussions.
There is no way to download Superdraw III.
If you download and Install Autodesk Simulation Mechanical 2013, you can access the old Superdraw III modeling environment simply by double clicking on the special executable:
C:\Program Files\Autodesk\Simulation 2013\dxfxport.exe
-Sualp
