This just started happening to a coworker and myself. We found a knowledge base subject with the same name but it was useless. And speaking of useless, this renders Simulate absolutely useless. Exactly how are you supposed to get help with such a serious issue?
Hi rlkillian,
You can either contact Technical Support (http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13806911) and they will ask you for clarifications, or you can provide some more details here and one of the readers may be able to help you. For example,
If something else comes to mind, I will post it.
My answers are in bold below:
Thanks for your interest. It seems like if its a permission problem it should be pretty easy to fix. If that is the problem the program should let you know that rather than just not working.
Hmmm. It is strange that it works with the model on the server but not on your local computer.
But your reply reminded me to mention that the data which is written by the Element Definition, Material, and Analysis Parameters is stored in the folder "my model name.ds_data\design scenario number\ds.mod", so that is the location where write priviledges are needed.
There was a problem years ago that occurred if the path became really long (~250 characters). So if this is a possibility, you may want to try saving the model to something really simple such as "C:\junk".
It just gets stranger and stranger. I tried your suggestion and copied the files to C:\junk. It worked! But then I thought it seems like a permissions issue to me so I copied it deep deep in the folder hierarchy to something not in the \users\myname\documents branch. This path was much longer than where the files are when they are giving me trouble. Guess what? It worked! This is just nuts. I checked my permissions in the offending folder and it says I have "full control".
I guess I'm just going to have to make a folder right off of C: for Simulate files but I hate band-aid solutions like that. I'm a control freak. I like to know what the computer is doing and why.
I generally like Autodesk products very much, but this is making me long for the day when I could pick up the phone and talk to a guy at Algor. I think his name was Mike. I went to a new job a few years ago where I didn't use Algor. I've since changed jobs again and I'm back in the fold but I lost his contact info. Don't know if he's still there or I would even be allowed to talk to a real human. As I say, I miss it.
Thanks for standing in the gap John.
