I'm trying to copy all the part attributes from an old model to a new one and It'll only let me read two at a time.
Any ideas why this would be?
Hi Andrew,
Here's what I see.
The first error message references the part attribute file as "blah blah - Rev A". This does not match the name of the file you selected, so there may be something in the filename that it doesn't like.
I do not remember the rules for importing multiple apif files, so that may have something to do with it. The documentation will clarify the capabilities.
Thanks John,
According to this it should work for a different model in the manner I'm using it.
See excerpt below.
When the Save command is used, a Browse For Folder dialog box is presented. Choose where to save the files and click the OKbutton. The name of the file is automatically set as follows: <FEM File Name>_<Design Scenario>_<Part Number (Part Name)>.apif where <FEM File Name> is the name of the model, <Design Scenario> is the design scenario number, and <Part Number (Part Name)> is the number and name of the part with the name enclosed in parentheses (). All attributes of the part (color, description, element type, element definition, and material data) are saved.
When the Read command is used, a standard Windows Open dialog box is presented. Select one or more apif files to read and click the Open button. Then, the Select Attributes to Apply dialog box appears. Choose which items to read from the files and apply to the selected parts. The multiple selection capability behaves as follows:
We still can't get this to work.
It seems like the number of parts it will load arbitraily changes from model to model.
Since the part names wont link with the surface names in Inventor, and the part names are overwritten when an .ipt is used to udate the model, this is the only tool we have for keeping part names when updating a model.
Maybe a request to link surface names in IV and part names in SIM would be a good idea?
