Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor
12 Kudos
Reaction Time to Cancel Job
152 Views, 3 Replies
10-08-2012 04:37 AM
I started a job the other day, and realized after a short while that I missed an optimization step that would reduce my mesh, so I decided to cancel it.  It took some 20-30 minutes (I finally just minimized the window to wait it out) before the program allowed me to go back into the model to make the changes.  Is this normal?
--Scott
Scott G.
Using Inventor 2013/2014 and Vault Basic since 2012
Using Simulation Flow 360 since 2013 (sparingly, bear with me please)
6 years Solidworks (v2006-v2010)
10 years Pro-Engineer (v13-WF2) w/ Intralink (2.0-3.0) w/ Pro/Mechanica
2 years of Mechanical Desktop
AutoCAD since R12
First professional CAD: DrafixCAD
Active Contributor
12 Kudos
Re: Reaction Time to Cancel Job
10-08-2012 07:20 AM in reply to: sgold
Need to clarify I realized.  I was using Simulation Flow 360.
Scott G.
AutoCAD since R12
18 Kudos
10-08-2012 08:29 PM in reply to: sgold
Cancel the process through task manager. They run separate to AlgFrame.exe so you will just return to the graphical interface.
I don't know why these processes take so long, I would expect it to be instant but it is similar in SolidWorks too. Would be good if someone from Autodesk could shed some light on this.
Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
Employee
8 Kudos
10-09-2012 08:58 AM in reply to: Inv_kaos
I'm not sure about Flow 360.
For Mechanical and Multiphysics, once a simulation is started, it goes into pre-processors and then processor(solver). No matter which stages it is at, we don't intend to kill a running code, since this would cause some data damage. So usually only a flag is set after a cancel signal is received. Code is going to check this flag at a moment when is safe to itself. So this Cancel only means a signal, instead of immediate reaction. In some specific case, this could take 20 minutes, or even longer.
Of course, to kill it in task manager is an option, but it might cause model damage.
If this response answers your concern, please mark it as "solved".
