Discussion Groups
Simulation Mechanical and Multiphysics
Active Member
0 Kudos
Reaction in Fluid Analysis
200 Views, 1 Replies
01-08-2013 09:56 PM
Simulation Multiphysics 2012
I'd like to know how to display the reaction force vectors in a 2D planar unsteady fluid flow
analysis like the example below:
     http://forums.autodesk.com/t5/Autodesk-Simulation-Mechanical/Lift-Drag-Forces/m-
p/3405695/highlight/true#M3717
I enclosed an example where the Reaction Forces button doesn't work.
127 Kudos
Re: Reaction in Fluid Analysis
01-09-2013 09:25 AM in reply to: ChaliBiky
I did not have the time to look at your model, but chances are you need to activate the option to calculae the reaction forces before you run the analysis. If I remember correctly, it is located under "Setup > Model Setup > Parameters > Output (tab)" and you will see where the reaction force option is set to "do not calculate" by default.
Hope this is the solution.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
Simulation Mechanical user since Dec 1997
