Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Reaction in Fluid Analysis
1 REPLY 1
ChaliBiky
500 Views, 1 Reply
Simulation Multiphysics 2012
I'd like to know how to display the reaction force vectors in a 2D planar unsteady fluid flow
analysis like the example below:
     http://forums.autodesk.com/t5/Autodesk-Simulation-Mechanical/Lift-Drag-Forces/m-
p/3405695/highlight/true#M3717
I enclosed an example where the Reaction Forces button doesn't work.
1 REPLY 1
AstroJohnPE
in reply to: ChaliBiky
I did not have the time to look at your model, but chances are you need to activate the option to calculae the reaction forces before you run the analysis. If I remember correctly, it is located under "Setup > Model Setup > Parameters > Output (tab)" and you will see where the reaction force option is set to "do not calculate" by default.
Hope this is the solution.
