Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor tim
Active Contributor
tim
Re: Surface bearing load error
371 Views, 2 Replies
08-22-2013 09:27 PM
I'm getting related errors with the bearing load tool.  The total reactions were less than i thought so i checked.  When I viewed the results mode, Their were two sets of arrows, the ones going down were correct but there was a second set going up which I did not ask for!  The second set were causing the error in reactions.
I suggest this tool be checked out.
Thanks, Tim
Please use plain text.
Valued Mentor
AstroJohnPE
08-23-2013 10:01 AM in reply to: tim
Hi Tim,
I was not able to reproduce your problem, so I suggest that you send an archive of your model to technical support. If you cannot get it to them for some reason, you could post the archive to the forum. See "Create, Post, or Provide an Archive of your model" for all of the archiving details.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
Product Support
dean.rose
07-02-2014 03:55 PM in reply to: AstroJohnPE
Hello Tim,
I wanted to move this post to a new thread since I believe it may be a slightly different issue. I was researching another issue and wanted to see if you were still having issues. One of the problems I have noted is related to the use of brick elements with midside nodes included in the element definition. This looks like a defect so if you are still having issues I would like to take a look at your model.
Dean
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Dean Rose
