I'm running an MES with large deformations (plastics) and contact. It is basically a bag which I apply a pressure on (shell elements) and allow to expand. However, there is contact invovled, and it seems that depending on some contact settings and the material properties, sometimes I get the error shown below:
Time Percent DT L Iter. Residual
0.000000 0.00 0.100000 1 0 0.0000E+00
0.100000 10.00 0.100000 1 1 1.0000E+00
0.100000 10.00 0.100000 1 2 9.7122E-02
0.100000 10.00 0.100000 1 3 9.5230E-01
0.100000 10.00 0.100000 1 4 9.9943E-01
0.100000 10.00 0.100000 1 5 1.0000E+00
0.100000 10.00 0.100000 1 6 1.0000E+00
0.100000 10.00 0.100000 1 7 1.0000E-02c
ERROR: Vector length = NaN Vector= NaN NaN NaN
Possibly bad normal vector or guiding vector direction.
forrtl: severe (37): inconsistent record length, unit 33, file C:\Windows\system32\fort.33
Image PC Routine Line Source
arun4.exe 0000000140E176C4 Unknown Unknown Unknown
arun4.exe 0000000140E12EDD Unknown Unknown Unknown
arun4.exe 0000000140DB580E Unknown Unknown Unknown
arun4.exe 0000000140D9C73D Unknown Unknown Unknown
arun4.exe 0000000140D9BBDD Unknown Unknown Unknown
arun4.exe 0000000140D7661E Unknown Unknown Unknown
arun4.exe 0000000140005282 DOHEAD 72 dofile.for
arun4.exe 0000000140441170 EXITN 94 yexitn.for
arun4.exe 0000000140760AE6 CLEANQUIT 148 cleanq.for
arun4.exe 0000000140717927 SETRST 72 shnorm.for
arun4.exe 00000001406BB7EF SHELKM 893 shell1.for
arun4.exe 00000001406BA403 SHELKM_WRAP 24 shell1.for
arun4.exe 00000001403A6165 SHELL 273 shell.for
arun4.exe 0000000140092FAE ELEMNT 82 zelemnt.for
arun4.exe 000000014023004A UNBLDF_BODY 974 xzutil1.for
arun4.exe 000000014022DB52 UNBLDF 665 xzutil1.for
arun4.exe 0000000140691E18 EQUIT4 608 xequit4.for
arun4.exe 00000001407FCBC3 NLLOOP 83 equilibr.for
arun4.exe 00000001407E540C VSS_IMPL 615 vssimpl.for
arun4.exe 000000014039D7FA FMAIN 600 yapak4.for
arun4.exe 0000000140493A7D MAIN__ 327 fallocn.for
arun4.exe 0000000140E1FC84 Unknown Unknown Unknown
arun4.exe 0000000140DF2A75 Unknown Unknown Unknown
kernel32.dll 0000000076E3F56D Unknown Unknown Unknown
ntdll.dll 0000000076F73021 Unknown Unknown Unknown
I assume it has something to do with calculating the normal vector for the contact force, but I'm at a loss of how to handle the problem. Any suggestions?
Björn
It seems this error is from normal direction calculation for shell element.
One of the possible reasons could be badly distorted shell element due to plastic material model.
I really appreciate it If you can share your model.
BTW: what's the version of your MES?
Yes, that's what I was thinking. I'm uploading the archive file now.
Do you think it could be due to my definition of the normal point? I always assumed that it was enough to create a point on the right side of the element, and then this would be understood by other elements of the part, even if the surface happens to be curved. Is this a misunderstanding on my part?
After reducing the step size, the model runs well.
Thanks for sharing your model, and I think the code should at least handle the exception in a better way.
Ok, thanks. Regarding my other question, about the orientation of shell elements, did I misunderstand the way it was supposed to be defined?
Yes, what you did is good enough. The shell element normal here is for setting the correct direction for contact and/or pressure load.
The Nan error is not related to this setting.
In a general nonlinear analysis, codes try to find the solution with iteration methods. Sometimes, these estimated solution is so bad that elements become distorted. In this situation, codes either stop or automatically try smaller step size.
In your model, codes try to quit but trigger some I/O error.
So your model is totally fine and small step size will help codes converge to the accurate solution quickly and easily.
Ok, I am getting this error message constantly in one of my models including shell elements (hyperelastic ones). Is the only way to get around this to reduce step size? That would make the runtime ridicolously long. I will try to apply the load slowly at first (to allow unfolding, where most of the shell normal directions probably change) and then apply it more drastically.
Can we hope to see this fixed in future versions of Algor?
One defect has been reported. And the fixe will be added in the next new release (Autodesk Algor 2012): MES will reduce time step with message rather than crash in this case.
-Shoubing
The fix in Autodesk Algor 2012 has been done. The code will automatically reduce time step with outputing the follow message:
** Time step reduction due to: bad normal vector or guiding vector direction
However, the user needs to make sure the guiding vector direction is correctly set.
