I am having a cylindrical part which is filled with a fluid, and rotates. To avoid having to do several models of the same thing and changing them in CAD, I was thinking of doing one full model, which has a hydrostatic pressure applied at the inside, following load curve 1, ramping up to full load at 1s, and constant at full load til 2s. Then, the prescribed displacement follows a load curve 2, which ramps from zero to full from 1s to 2s. My question is, I guess, does the hydrostatic pressure also updates with this prescribed displacement? It should be, but I just want to make sure.
Björn
Solved by S.LI. Go to Solution.
As shown in the attached file, please check "Follows Displacement" to make the hydrostatic pressure following the surface movement.
