Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Pulling test of cable
3 REPLIES 3
shuaib_cad
574 Views, 3 Replies
I want to perform an analysis in Autodesk Simulation Mechanical 2014. Please advice.
I have an assembly which has a connector (hollow shaft) and a cable (shaft).
The cable is inserted in the connector and crimping operation is done.
How to calculate the maximum pulling force of the cable, if a force is applied on the top face of the connector?
Please look at the image for more clarity.
Regards
K. Mohammed Shuaib
3 REPLIES 3
cieslak.maciek
in reply to: shuaib_cad
So you want maximum force before it breaks the connection, right?
shuaib_cad
in reply to: cieslak.maciek
A force of say some 50N is applied on the hollow shaft which will deform both the parts.
After the deformation is done, the inside shaft (cable) is pulled out.
I want to know the force required to pull the inside shaft (cable) from the hollow shaft.
How do a carry out this analysis on Simulation mechanical 2014.
I am not able to transfer the deformed results from one scenario to another scenario.
Regards
K. Mohammed Shuaib
AstroJohnPE
Hi Mohammed,
You do not need two scenarios. Think of it as one analysis with two events:
  1. Use forces or prescribed displacements to crimp the outer tube. So these loads would be assigned to load curve 1 which ramps the load from 0 to maximum during the time 0 to T1. From T1 until the end of the analysis, the load is 0.
  2. Then a force pulls on the inner tube. So this load would be assigned to load curve 1 which ramps the load from 0 to maximum during the time interval of T1 until the end of the analysis.
