I want to perform an analysis in Autodesk Simulation Mechanical 2014. Please advice.
I have an assembly which has a connector (hollow shaft) and a cable (shaft).
The cable is inserted in the connector and crimping operation is done.
How to calculate the maximum pulling force of the cable, if a force is applied on the top face of the connector?
Please look at the image for more clarity.
Regards
K. Mohammed Shuaib
Solved by AstroJohnPE. Go to Solution.
A force of say some 50N is applied on the hollow shaft which will deform both the parts.
After the deformation is done, the inside shaft (cable) is pulled out.
I want to know the force required to pull the inside shaft (cable) from the hollow shaft.
How do a carry out this analysis on Simulation mechanical 2014.
I am not able to transfer the deformed results from one scenario to another scenario.
Regards
K. Mohammed Shuaib
Hi Mohammed,
You do not need two scenarios. Think of it as one analysis with two events:
