Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Propeller Fluid Analysis
3 REPLIES 3
mnpatterson08
552 Views, 3 Replies
I am new to Autodesk simulation, and I can't figure out how to analyze the air fluid output for an airplane propeller. I haven't been able to find any tutorials, are there any out there? Or could someone make a quick list of steps of what I should be doing please?
3 REPLIES 3
PipePakPat
in reply to: mnpatterson08
Autodesk Simulation Multiphysics' fluid flow does not consider changes in fluid density.  For this reason, Mach numbers below 0.3 can be analyzed and considered to be acceptable.  An air plane propeller is more than likely exceeding this limitation.  Autodesk also offers "Autodesk Simulation CFD" (formally CFDesign) which is more capable in solving this type of analysis.
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
in reply to: PipePakPat
would this also be the case for (say for example) the ports on a cylinder head for an IC engine?
John_Holtz
Hi Brendan,
If the compressibility of the air in your engine simulation is important, then Simulation Mulitphysics is not the product that you want to use. Please use Simulation CFD when compressibility effects are important.
For the engine, there are other factors involved beyond the propeller example that was originally asked: namely combustion. I am not sure whether Simulation CFD can handle that aspect or not, but your description and my limited knowledge of I.C. engines lead me to believe that the combusion may not be involved in what you are trying to obtain. Smiley Embarassed
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
