Claus,
This type of message can occur on computers having more that 16 GB RAM. In this case, one may be required to reduce the amount of allocated RAM in the Analysis Parameters screen from 50% to 20%.
The other limitation is that the processor will need enough RAM to load each part into an array. If a single part has a huge number of elements and the computer doesn't have enough RAM, then one will be required to either use a more coarse mesh, or to divide the part into 2.
These suggestions describe how to address either having too much RAM or too little.
Pat Tessaro, P.E.
Autodesk Inc.
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
