Discussion Groups
Simulation Mechanical and Multiphysics
9msl1
Problem with Simulation Multiphysics, non-linar natural frequencies
52 Views, 0 Replies
03-21-2014 10:30 AM
Hello
I can run a Natural Frequencies non-linear analysis but when I want to change the load case (to see the different modeshapes)  Autodesk seems to freeze for hours and not change.
After analysis the first modeshap appears no probelm but then I cant =access the rest.
Is there a way to trick the results to load the 2nd load case instead of the 1st when I switch to the results window?
Please use plain text.
