Hello
I can run a Natural Frequencies non-linear analysis but when I want to change the load case (to see the different modeshapes) Autodesk seems to freeze for hours and not change.
After analysis the first modeshap appears no probelm but then I cant =access the rest.
Is there a way to trick the results to load the 2nd load case instead of the 1st when I switch to the results window?
