Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
422 Views, 1 Reply
Pressure Testinng
Hello all,
I need to perform a pressure test on a car radiator section (any section). i want to know which is the most probably area to be affected (it should be at the joints right ?)
I want to know in what way should i proceed the modelling ?
Should i consider only the joint ?
and how do i apply the boundary condition if i want to apply a pressure of 10 bar, and how will i evalute the result from it.
Thank you.
1 REPLY 1
Sualp.Ozel
What is the goal of your simulation?
