I am using Simulation Mechanical 2015.
I am trying to precisely translate a slice plane x inches from the origin of my model then rotate it about an axis in the model alpha degrees. This is due to the obround shape of the model I am analyzing. Is there a way to precisely translate and rotate a slice plane?
It appears that the axis for rotation of the slice plane is not something that can be defined. Also it appears that translation of a plane can only be done by draging the plane an to an approximate location.
