Is there an easy way to measure percent (nodes or volume) of a model that is over over/under a number (tensile yield for example)? In my project requirements no more than 10% of an FEA model may exceed yield. By visual inspection I'm borderline.
I can export the nodal information to Excel, but that's cumbersome considering the large number of nodes in the model I'm working with. I was hoping there was an easier way.
mark
Solved by John_Holtz. Go to Solution.
I'm not sure this is going to work
1.) hide all yield elements
2.) measure the volume of remainings. (I know algor could measure volumne, but I'm not sure if it could do it for portion of a model)
Hi Mark,
To elaborate on what S.Li said, here's a broad overview of the steps. (Sorry, but I'm doing this from memory, so some of the steps or terminology may be off a little.)
Thanks John for these details.
And it works, except for that you have to uncheck "results options -> smooth results" before inquiring element volumes.
