I have a vessel that I have analyzed using 3d elements. There are areas where the geometry makes abrupt changes and so I have to use the Stress Linearization tool to determine the bending and membrane stresses in that area.
My problem is, when I launch the Stress Linearization tool, it sits there for about 30 seconds and then gives me the error:
Run-Time Error '7' - Out of Memory
My machine has 12GB of RAM and I've got Resource Monitor open. I've still got over 6GB free. Anybody have any idea why this is happening?
As an additional data point, I tried another, much simpler model just to make sure it wasn't model dependent. The simpler model works just fine.
Perhaps my model is just too big?
The model that is failing has the following properties:
**** Symbolic Assembly Using the Row-Hits Matrix Profile ... **** Number of equations = 571016 Estimated maximum bandwidth = 616 Estimated triangle matrix nonzeroes = 48978954 Symbolically assembled nonzeros = 10577288 **** Real Sparse Matrix Assembly ... 1**** STIFFNESS MATRIX PARAMETERS minimum non-zero diagonal element = 1.6686E+06 maximum diagonal element = 1.3930E+09 maximum/minimum = 8.3484E+02 average diagonal element = 5.5878E+07 Minimum found at equation #197840: node = 66942 DOF=Tz Maximum found at equation #519225: node = 174477 DOF=Tx in the upper triangle: number of entries in the profile = 48978954 number of nonzeros = 10574982 **** Sparse Matrix Assembled **** Invoking Parallel BCSLIB-EXT Sparse Solver... **** Load Cases 1 BCSLIB-EXT solver memory status: in-core memory requirement (MB) = 1518.89 minimum memory requirement (MB) = 168.42 user specified memory (MB) = 3063.65 available physical memory (MB) = 3063.65 available virtual memory (MB) = 9310.69 memory currently allocated (MB) = 1518.89 **** End Sparse Solver Solution Reaction Sums and Maxima for Load Case 1 Sum of applied forces X-Force Y-Force Z-Force X-Moment Y-Moment Z-Moment 1.4128E+04 -3.5282E+04 -1.0943E+04 0.0000E+00 0.0000E+00 0.0000E+00 Sum of reactions X-Force Y-Force Z-Force X-Moment Y-Moment Z-Moment 2.0652E-06 -1.4710E-06 -4.1880E-06 0.0000E+00 0.0000E+00 0.0000E+00 Sum of residuals X-Force Y-Force Z-Force X-Moment Y-Moment Z-Moment 1.4128E+04 -3.5282E+04 -1.0943E+04 0.0000E+00 0.0000E+00 0.0000E+00 Sum of unfixed direction residuals X-Force Y-Force Z-Force X-Moment Y-Moment Z-Moment 3.0113E-06 -9.9219E-06 2.0335E-06 0.0000E+00 0.0000E+00 0.0000E+00 Largest applied forces and moments Node Node Node Node Node Node X-Force Y-Force Z-Force X-Moment Y-Moment Z-Moment 135382 133210 135468 0 0 0 -4.4066E+06 -2.5280E+06 -4.4735E+06 0.0000E+00 0.0000E+00 0.0000E+00 Largest nodal reactions Node Node Node Node Node Node X-Force Y-Force Z-Force X-Moment Y-Moment Z-Moment 135382 133210 135468 0 0 0 4.4066E+06 2.5280E+06 4.4735E+06 0.0000E+00 0.0000E+00 0.0000E+00 Largest nodal residuals Node Node Node Node Node Node X-Force Y-Force Z-Force X-Moment Y-Moment Z-Moment 45106 36254 67713 0 0 0 1.0326E+04 -1.2056E+03 1.9515E+03 0.0000E+00 0.0000E+00 0.0000E+00 Largest unfixed direction residuals Node Node Node Node Node Node X-Force Y-Force Z-Force X-Moment Y-Moment Z-Moment 137419 107753 149440 0 0 0 -1.8021E-07 -4.9639E-07 -1.3784E-07 0.0000E+00 0.0000E+00 0.0000E+00 1**** TEMPORARY FILE STORAGE (MEGABYTES) ---------------------------------- UNIT NO. 7 : 4.358 UNIT NO. 8 : 8.777 UNIT NO. 9 : 0.000 UNIT NO. 10 : 0.000 UNIT NO. 11 : 0.000 UNIT NO. 12 : 4.357 UNIT NO. 13 : 4.361 UNIT NO. 14 : 0.000 UNIT NO. 15 : 0.000 UNIT NO. 17 : 0.000 UNIT NO. 50 : 548.980 UNIT NO. 51 : 56.596 UNIT NO. 52 : 447.108 UNIT NO. 54 : 2.178 UNIT NO. 55 : 40.340 UNIT NO. 56 : 80.681 UNIT NO. 57 : 80.681 UNIT NO. 58 : 0.000 UNIT NO. 59 : 0.000 TOTAL : 1278.417 Megabytes
