Discussion Groups
Simulation Mechanical and Multiphysics
Distinguished Contributor
4 Kudos
One direction translation constraint
182 Views, 1 Replies
09-11-2012 07:09 AM
Hello Everyone,
The question is fairly simple:
1- Is it possible to create a constraint in Non-Linear Analysis so that a node would not be able to displace in one sense of, lets say, X, but to be allowed to displace towards the other sense?
Thanks for the reply!
129 Kudos
Re: One direction translation constraint
09-11-2012 08:42 AM in reply to: scudelari
Hi scudelari,
You would need to use some type of contact to accomplish that type of "constraint". Which option you choose depends on the particulars of the model, but the ones that come to mind are the following:
  • One of the contact elements (Contact, Coupling, or General contact elements)
  • Surface-to-surface contact
  • Impact plane.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
Simulation Mechanical user since Dec 1997
