Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
non linear Material datasets in mechanical
4 REPLIES 4
phammer
434 Views, 4 Replies
hi everybody,
I want to simulate a polymer part in Polypropylene (PP) with non linear material behaviour.
Are there ready to use non linear materials in mechanical that I could use?
I think that depends a bit on the choosen material model.
Philipp
4 REPLIES 4
arizawilmer
in reply to: phammer
Hi
What version of autodesk mechanical simualtion are you using?
Wilmer Ariza
Researcher Control and SI with AI for autonomous underwater vehicles
PhD student(Australian Maritime College-University of Tasmania)
Master of engineering (Advance Manufacturing Technology- Swinburne University of Technology)
Mechatronic Engineer
phammer
in reply to: arizawilmer
I use mechanical 2015.
Philipp
FEM_TXF
Hi...to check the material database you have to first setup the type of non linear equations are you going to use......example first you set your material to hardening Von mises and then you setup your material.....there are a lot of material ready to use and you can also edit them...
p.hammer
in reply to: FEM_TXF
is there an overview what material grade is available depending on the matrialmodell?
Philipp
