I just installed Algor. I am trying to do a thermal analysis on a cpu waterblock but I cannot figure out how to model the simulation. The tutorials that come with algor don't really cover something like that. Can anyone point me towards a tutorial or a demo that shows some variation of pumped fluid over a cooling block? Or even something that is remotely similar would be helpful.
This one might be a good starting point:
http://download.autodesk.com/us/algor/tutorials/FEMPRO_Online_Tutorials.htm
detail explanation of your problem will help us help you better;)
On the above link look specially for the following two tutorials under :Analyzing and Evaluating Results Tutorials
Hey thanks for the tutorial links. I am really just trying to get the hang of algor. I just got it. I am trying to do a very basic analysis of the cooling ability of a cpu waterblock design. Until I get good with algor I am just doing a simple model. Basically a piece of copper that has a heating load on the bottom and channels in the top for water to be pumped through to carry the heat away. I want to create a temperature graph that shows the heat of the water as it passes through the block.
