Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Neutral Point is used before set
3 REPLIES 3
Alan_H
706 Views, 3 Replies
Received a new warning today when attempting to solve a non-linear model that causes the simulation to end.  It is: "WARNING: NEUTRAL POINT IS USED BEFORE SET".  I can't find any information on this type of a warning anywhere so I'm not even sure where to begin to try to address the issue.  Anyone have any ideas (or at least be able to tell me what typically causes this type of warning so I have some idea on what I need to do)?
Thanks, Alan
3 REPLIES 3
S.LI
in reply to: Alan_H
Hi, Alan,
Please share more details about your issue, such as the analysis type.
It would be great and helpful if you could post your log file here.
thanks.
If this response answers your concern, please mark it as "solved".
zhuangs
in reply to: Alan_H
You must be using frictional contact or frictional slide/no bounce contact in your model.  The following procesures might help test:
(1) Reduce time step by inputting a larger capture rate.
(2) Adjust a user-specified contact tolerance with a larger value than the automatic option.
-Shoubing
Alan_H
in reply to: zhuangs
Your correct.  It's a model with surface contacts.  The contact tolerances was the issue.  Pushing that up slightly took care of the problem.
