Hello --
I understand modal analysis. I need help when load stiffening is added.
1. Can load stiffening be used with axisymmetric and brick models?
2. Are the loads applied just as though this were a static analysis? If not, then how?
3. What kinds of loads can be applied (nodal forces, surface forces, pressures)?
4. Are there any tutorials?
Thanks.
Don Culp
Hi Don,
FYI: Another source of "tutorials" is in the documentation under the section "Examples". I know that there is not one for modal analysis with load stiffening, but this source may help someone else that reads this thread.
John --
There is supposed to be a tutorial here (http://engineeringexploration.autodesk.com/content/section-2-linear-material-analysis) in Module 5 (2.5 Part B: Frequency Analysis Load Stiffening). Unfortunately, both videos are for the same lesson (2.5 Part A: Frequency Analysis Linear Systems).
