Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Multiple flow paths/tubes simulation
0 REPLIES 0
Message 1 of 1
293 Views, 0 Replies
Dear all,
I was curious if it is possible to simulate a system, where I have multiple tubes embedded in foam, with  each tube carrying a different fluid  (unique flow velocities & fluid densities) in Autodesk Algor ?
 I would like to see the temperature distribution as a final result (first run fluid flow & then transfer to heat transfer module).
Also, does Autodesk Algor has built-in foam material?
Any guidelines/hints are most appreciated.
Jay
0 REPLIES 0
