Discussion Groups
Simulation Mechanical and Multiphysics
New Member
msilvestri
Accepted Solution
Multiphysics - Binary files
185 Views, 5 Replies
11-27-2012 08:46 AM
Sombody knows if in multiphysics there is the posibility of converting/using binary results file ".aso"?
Please use plain text.
Valued Mentor
AstroJohnPE
Re: Multiphysics - Binary files
11-27-2012 10:20 AM in reply to: msilvestri
For everyone's benefit, the .ASO file is the stress results from an MES/Nonlinear Stress simulation. The format of the file is binary, so unless one writes a program to read the data, there is no way to access it directly. (Of course, the Results environment reads the file to display the results.)
There is a program to convert it from binary to text format. Look for "MKASO.EXE" located in the installation folder. Unfortunately, it looks like there is a problem with the builds for version 2013: MKASO is 0 bytes in size.
If someone has an older version of Simulation Mechanical/Multiphysics, or even old Algor software, could you zip the file MKASO.EXE and attach it to a reply.
If you want a limited set of data, you can use the command "File > Export > All Results" from the Results environment. The currently displayed results will be output to a file of your choice.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
New Member
msilvestri
11-28-2012 12:21 AM in reply to: AstroJohnPE
Fast, clear and effective astro- answer...
mirko
Employee
PipePakPat
11-28-2012 10:43 AM in reply to: AstroJohnPE
The last release that contained this binary to ASCII conversion executable was "Autodesk Simulation Mechanical 2012".  I have attached a copy of that executable.
Extract the attached "Mkaso_exe.zip" file to your Simulation installation directory, then rename the "Mkaso_exe.txt" file to "Mkaso.exe".  Be sure that your computer options allow you to see your file extensions so that the file is renamed properly.
Pat Tessaro, P.E.
Customer Support Engineer
Autodesk, Inc.
285 Kappa Drive
Suite 250
Pittsburgh, PA 15238
COzcan
05-07-2013 08:58 AM in reply to: msilvestri
Hello;
I came through this thread as I was searching for automation in ADSK Mech. Very helpful information indeed and thanks to you John.
I have a follow-up question regarding the .ado (displacement results) file. mkaso.exe does output a header only when supplied with ds.ado. Is there a mkado.exe or such in order to translate the nodal displacement results?
Best...
Can
Can Ozcan
AKRO Engineering
can.ozcan@akroengineering.com | www.akroengineering.com
Valued Mentor
AstroJohnPE
05-07-2013 05:41 PM in reply to: COzcan
You can translate the displacement results from the "Results Options" tab, then "Other > Tools > Nodal Results Translator". It can only handle files under 2GB in size which can e a problem with MES results in some extreme (?) cases.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
