Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Multiphase Flow Simulation in autodesk
2 REPLIES 2
tareq.me.kuet
935 Views, 2 Replies
I would really appreciate  some help in here.As my project has the invovement of hot air jet impingement on an iced surface(related to deicing of aircraft) i really want to know is it possible to do multiphase flow simulation on autodesk  simulation multiphysics/cfd.
i checked some brochure but i am not sure. Please tell me Autodesk simulation has the  capability of simulating multiphase flow or not.
i will look for an early reply.
thanks to all of you.
2 REPLIES 2
Joey.X
in reply to: tareq.me.kuet
Depending on the physcal problem and assumption, if there are density changes (or multiple conbination of multiple fluid matrials) in hot air jet impingement problem, SIM-MP will not handle it, you can check SIM-CFD product.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
