Can you edit the xyz location of a remote load?
Thanks.
Solved by John_Holtz. Go to Solution.
Dr. Palco,
You do not edit the location per se. The Remote Load command is really just a wizard to draw beam elements and add loads/constraints at the point. What you do is select the node and move to a different coordinate using the "Geometry > Tools > Point Move" command.
This command works on any node/vertex, not just remote loads.
