Hello Everyone,
I am simulation a long tower that has a gravitational load applied while having 3 points (center points of the lugs). The object is as follows
As you can see, the gravity is going down. Here is what I get from the results:
The probes indicate the Reaction Force, which is pretty close to what I had calculated manually.
But now, if I copy this load case and change the gravity to become as follows (face hidden just for this illustration)
That is what I get:
The weirdest part is that I get no error message.
I tried reducing the stiffness of the rigid links on the center of the lug holes, but to no avail.
I tried also appliying the gravity at 90 degrees and the same thing happened.
I tried recreating the mesh after coping it, but it was also to no avail.
Any ideas as why this is happening?
Thanks a lot!
Solved by scudelari. Go to Solution.
For a moment I considered deliting the entry, but than I though that this might be useful to someone else.
When I changed the diraction of the Gravity, the object could move towards the Y axis and this is what caused the problems.
So, if this ever happens, it is because your model is not properly fixed...
