Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Model Orientation Not Consistent with Inventor
3 REPLIES 3
andrewdroth
557 Views, 3 Replies
My model orientation changes from Inventor to Algor.
I'll save a model in Inventor with the top of the model consistent with the 'Top' on the view-cube. When I open the saved SAT file in Algor the top of the model is aligned with the 'Back' of the view-cube.
Any ideas why that would happen? Any options to correct this?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
3 REPLIES 3
andrewdroth
in reply to: andrewdroth
I should note that the Axis (X,Y,Z) stay the same. The difference is Algor uses the Z-axis as the vertical Axis, and Inventor uses the Y-axis as the vertical axis.
Ideally I'd like to change Algor to match Inventor.
Andrew Roth
rothmech.com
John_Holtz
Andrew,
If you are using Algor Simulation 2011, you can go to the "Tools > Options" menu. The "View Options" tab lets you choose the definition of "Front" and "Top". There are also pre-defined templates, so you can simply choose the template for Inventor.
P.S. This feature is new to 2011.
John Holtz
Product Design Engineer, Algor Simulation
Autodesk, Inc.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
andrewdroth
Thank you John,
That was exactly what I was looking for.
Andrew Roth
rothmech.com
