Hello
I want to run a Mechanical event simulation on a rubber object (Neoprene) using a viscoelastic Mooney-Rivlin material model.
I know how to set this up however there are no materials in the Autodesk library for this analysis type. When I do a normal Mooney-Rivlin material model only rubber shows up (as expected)
I noticed that any other element definition other than the default has no associated materials.
What can be done to resolve this? Can I download a viscoelastic Mooney-Rivilin Library somewhere on the internet (several hours of searching have not helped)?
In addition, I would like to run a simulation on stryrofoam but the same problem occurs. Any advice on how I'd simulate this?
Cheers!
