Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Message: Use SSAP0G or SSAP0GC for models containing gap or contact elements
3 REPLIES 3
mechamania
376 Views, 3 Replies
Hi
I'm using Simulation 360 pro.
So now and then I get this message when running analysis on the cloud:
"Use SSAP0G or SSAP0GC for models containing gap or contact elements"
When I try to run the same project later, it may run correctly, without error.
So it is not a problem with the project. Is this a capacity problem with the cloud servers?
3 REPLIES 3
mechamania
in reply to: mechamania
This is the message I get:
PipePakPat
Hi Cor,
This issue seems like it may be model dependent and I recommend to create an archive of the model and open a support case from within the Autodesk Subscription Center.
Pat
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
mechamania
I do not think it is model dependent. When I run the same model some time later, it may succeed.
It happens with all kind of projects. Simple simulations and complex simulations.
