Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Meshing problemon huge model
2 REPLIES 2
benalain13
319 Views, 2 Replies
I have a big model, that gives me strange behaviour during the meshing process:
the surface mesh is ok ;
when i ran the analysis (after having input BC, loads and materials), and so during the solid mesh process, some parts are not meshed at all and a message saying no lines in the parts is appearing...
So i wonder how can this happen....
Thanks for your ideas,
2 REPLIES 2
AstroJohnPE
in reply to: benalain13
Hi Alain,
I do not know what the problem is, so these steps will not solve your problem but may help to diagnose it.
  1. Hide all of the parts except for one of the parts that fails to solid mesh.
  2. Save an image of the part ("application button > Export > Image")
  3. Right-click on the part in the browser and choose "Create Solid Mesh".
  4. I do not know how the log will appear, but you can copy the text from:
a) maybe the dialog that shows the meshing progress while it is meshing?
b) from the "Mesh > Mesh > View Mesh Results" command, and somewhere it will show the log file
c) the file named "ds.xlg" located in the .ds_data\design scenario folder.
Attach the image and the text from the solid meshing log to your reply.
benalain13
Hi John
I will test your tips
FYI, this has been sent to tech support, under the below reference
CaseNo:08595545
Regards
