vex,
It is true that several nodes are required to define flow through a passage, and your model will need to be meshed differently to allow flow. Access the "MESH|Model Mesh Settings" pull-down menu sequence and choose the "Options" button. Click on the "SOLID" icon in the left margin and choose "Tetrahedra and Wedges (boundary layer)" meshing option and choose "OK". Next, select the surface at the end of the passage, then right-click and choose "CAD MESH OPTIONS|Exclude From Boundary Layer". One can then mesh the model.
In regard to the meshing error produced below. If the error message appears again, access the "FILE|ARCHIVE|Create" pull-down menu sequence and choose to create an archive of the model only. Upload the resulting *.ach file for review.
Pat Tessaro, P.E.
Autodesk Inc.
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
6425 Living Place
Suite 100
Pittsburgh, PA 15206
