Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
MES - Pressurized pipe analysis
3 REPLIES 3
sapayne
623 Views, 3 Replies
Hi
I'm analyzing the beviour of a PVC pipe with an inlaid metal coil using MES. In the model the pressure ramps from 0-3MPa over one second. I ran a preliminary run on a long section of pipe and the analysis ran well and produced reasonable resutls. I then tried a different pitch on the metal coil and a shorter span, and the results were non-sense. See the attached figures.
Any thoughts? I used the same setup and a very similar CAD model.
Shannon
Tags (2)
3 REPLIES 3
sapayne
in reply to: sapayne
More photos illustrating successful analysis
ilyas_drawbridge
My guess is that the mesh does not match between the two parts. Examine visually, or perform a static stress analysis to see if the model is adequately constrained with just a constraint on one part.
Regards
Ilyas
zhuangs
in reply to: ilyas_drawbridge
I agree that the mesh betwenn different parts are not matched.  You can remesh the model with the default contact setting of "Bonded".
-Shoubing
