Hi, Gents.
Descripiton of the task: 1 part - platform with hills and one hole, 2nd - the ball which must matched with the hole. The main problem - how to make horizontal motion of the ball and what type of the contact is need to use. The model archive i've attached below
I checked the model. You added precribed displacement on the whole ball part. How to control the horizontal motion of the ball part depends on motion of the ball, rotation or only translation.
In your model, the dirction of translation has a vector, with a value of on Y- will seperate the ball with the platform at some area.
The contact type to be used really depends on the model, frictionless, frictional or no slide. This needs more infomation about the model.
-Shoubing
Hi Eugene,
I do not have the software with me at he moment, so I could not look at your model. But one type of load you can apply is an initial velocity. That might be applicable for a ball that is presumably rolling at time 0.
An "initial velocity" cannot work for that model, based on the surface shape, and the ball will run to different direction :).
Since the displacement of the ball to the hole has both component along X- and Z- direction, using one "Part Prescribed displacement" with a vector direction must influence on Y- direction. In this case, we can define two "Part Prescribed displacement" groups, one is along X-, and one is along Z-. You need to determine their maginitudes. Along Y- direcion, the model has gravity, which will keep the ball contact with the platfrom, and then fall into the hole.
-Shoubing
They are the same, but different definition, one is the trees in FEA Editor, the other is using General Surface-to-Surface contact dialog.
-Shoubing
