Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
MES - event duration problem
5 REPLIES 5
kohlerf
597 Views, 5 Replies
Hello everyone,
I have a problem with setting up MES with durations of less than 1s (s. screenshot, red frame).
The program seems to accept whole numbers only. If I enter 0.1 (0,1 in Germany) it is set to 1 automatically.
Has anyone an idea how to change this. Maybe it is a restriction of the student version of the software?!
I am using the student version of Autodesk Mechanical 2014 64bit in German.
Thank you very much in advance!
5 REPLIES 5
AstroJohnPE
in reply to: kohlerf
I suggest you try entering 0.1 (with a period. not a comma,) There may be some areas of the software that do not use the Windows regional settings.
kohlerf
in reply to: AstroJohnPE
Thank you for your response!
I've already tried your advice, however the software does not accept a period instead of a comma. If I enter 0.1 it is automaticall set to 1. If I enter 1.1 it is automaticall set to 11 and so on.
Do you have any further ideas? I could try reinstalling the software.
kohlerf
The problem occurs in "MES with nonlinear materials" scenarios only.
As soon as I switch to static stress analysis with nonlinear materials, I can apply shorter durations.
Roelof.Feijen
A reinstall won't change anything. If have seen this before. Change the decimal settings. Use the period as a decimal setting.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
kohlerf
in reply to: Roelof.Feijen
Thank you very much. Everything works fine now.
