Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor
nosborne
Accepted Solution
Mechanical 2013 - Measure function causes Crash
154 Views, 2 Replies
11-27-2012 11:39 AM
I imported a small IGES file containing a few lines and arcs. When I use the "measure" tool the software crashes and corrupts the database so that it cannot be re-opened. I tried creating a few lines directly in Simulation and the same thing happened when I used the "measure" tool with that model. I have not had issues with it prior to version 2013. Anybody else have the same experience?
Please use plain text.
Employee
Sualp.Ozel
Re: Mechanical 2013 - Measure function causes Crash
12-04-2012 01:11 PM in reply to: nosborne
I am running Simulation Mechanical 2013 Service Pack 2 on a Win7 (64 bit) machine with 16 GB RAM and I do not experience a crash using the "Measure" tool in "FEA Editor" or "Results" environements
Active Contributor
nosborne
12-04-2012 01:20 PM in reply to: nosborne
I discovered that Service Pack 2 solves the problem (along with other issues I was experiencing). Thanks.
