I imported a small IGES file containing a few lines and arcs. When I use the "measure" tool the software crashes and corrupts the database so that it cannot be re-opened. I tried creating a few lines directly in Simulation and the same thing happened when I used the "measure" tool with that model. I have not had issues with it prior to version 2013. Anybody else have the same experience?
Solved by nosborne. Go to Solution.
I am running Simulation Mechanical 2013 Service Pack 2 on a Win7 (64 bit) machine with 16 GB RAM and I do not experience a crash using the "Measure" tool in "FEA Editor" or "Results" environements
